[petsc-dev] Rebuilding pets-library only
Barry Smith
bsmith at petsc.dev
Wed Feb 17 19:10:13 CST 2021
Blaise,
I think I fixed this a few months ago for petsc4py. It is suppose to have the right dependencies so petsc4py does not get rebuilt if it does not need to be. (For example it depends on the PETSc include files but not on the PETSc source files).
If it still insists on rebuilding petsc4py when it should not in master please let us know the details so we can fix this.
Barry
> On Feb 17, 2021, at 10:17 AM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Thanks
> Blaise
>> On Feb 17, 2021, at 10:03 AM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>> make libs should do that.
>> Blaise A Bourdin <bourdin at lsu.edu <mailto:bourdin at lsu.edu>> writes:
>>> Hi,
>>> Is there a way to rebuild the petsc library only, skipping rebuilding mpi4py and petsc4py if petsc is configured with them? I know I can ctrl-C this step if all I want is to rebuild the lib, but I would not mind a more elegant way..
>>> Regards,
>>> Blaise
>>> A.K. & Shirley Barton Professor of Mathematics
>>> Adjunct Professor of Mechanical Engineering
>>> Adjunct of the Center for Computation & Technology
>>> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
>>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin <http://www.math.lsu.edu/~bourdin>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210217/474b27cd/attachment.html>
