[petsc-dev] PETSC MPI error
Mark Adams
mfadams at lbl.gov
Tue Feb 9 14:49:29 CST 2021
I see this message when I run at problem on Fugaku:
05:45 master= ~/petsc/src/snes/tests/data$ more hello.5067177.err.1.9
PETSc Error --- Open MPI library version
FUJITSU MPI Library 4.0.0 (4.0.1fj4.0.0) does not match what PETSc was
compiled with 4.0, aborting
This is on master. Any ideas?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210209/d078c2ce/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210209/d078c2ce/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210209/d078c2ce/attachment-0003.obj>
