[petsc-dev] PETSC MPI error
Barry Smith bsmith at petsc.dev
Tue Feb 9 22:03:45 CST 2021
   Ok, they use the OpenMPI version naming in their include files but changed the name in  MPI_Get_library_version() to make it look like they wrote their own MPI :-).
   I guess we are too picky in our testing, in pinit.c you can change to
    /* check for OpenMPI version, it is not part of the MPI ABI initiative (is it part of another initiative that needs to be handled?) */
#elif defined(OMPI_MAJOR_VERSION)
      char *ver,bs[32],*bsf;
      ierr = PetscStrstr(mpilibraryversion,"Open MPI",&ver);if (ierr) return ierr;
      if (ver) {
        PetscSNPrintf(bs,32,"v%d.%d",OMPI_MAJOR_VERSION,OMPI_MINOR_VERSION);
        ierr = PetscStrstr(ver,bs,&bsf);if (ierr) return ierr;
        if (!bsf) {
          fprintf(stderr,"PETSc Error --- Open MPI library version \n%s does not match what PETSc was compiled with %d.%d, aborting\n",mpilibraryversion,OMPI_MAJOR_VERSION,OMPI_MINOR_VERSION);
         return PETSC_ERR_MPI_LIB_INCOMP;
#endif
> On Feb 9, 2021, at 2:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I see this message when I run at problem on Fugaku:
> 05:45 master= ~/petsc/src/snes/tests/data$ more  hello.5067177.err.1.9
> FUJITSU MPI Library 4.0.0 (4.0.1fj4.0.0) does not match what PETSc was compiled with 4.0, aborting
> This is on master. Any ideas?
> Thanks,
> Mark
> <make.log><configure.log>
