[petsc-dev] About parallel of ILU
Mark Adams
mfadams at lbl.gov
Tue Feb 9 08:11:10 CST 2021
On Tue, Feb 9, 2021 at 4:31 AM Chen Gang <569615491 at qq.com> wrote:
> Dear Professor,
> I have a question about the bjacobi+ilu, I'm in the place
> src/ksp/ksp/tutorials
> and running the ex2 with
> mpirun -np 40 -bind-to core ./ex2 -m 2000 -n 2000 -ksp_max_it 1000000
> -ksp_rtol 1e-10 -ksp_type gmres -pc_type bjacobi -sub_pc_type ilu
> -sub_pc_factor_levels 10 -ksp_monitor_short
> on the Intel machine with 40 cores, the petsc is complied with MKL and
> ICC/MPIICC with O3.
> I found the numerical results are not the same from time to time, although
> they all right, the iterations are not exactly the same from time to time.
> Where have I done wrong?
Humm, iterations should rarely change. You can see floating point scale
differences. Try jacobi instead of ilu and/or try not using MKL.
> I'm looking forward to hear you!
> Best,
> Gang Chen
> Sichuan Univertsity,
> School of Mathematics,
> Chengdu, China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210209/94408cc8/attachment.html>
