[petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
    Barry Smith
    bsmith at petsc.dev
    Mon Dec 13 20:36:46 CST 2021
  If these are temporary work files could you not have them end with .c etc maybe have an extra .tmp at the end or something so they don't mess with everything if they are lying around? It is annoying to have to keep deleting them all.
> On Dec 13, 2021, at 9:32 PM, Barry Smith <bsmith at petsc.dev> wrote:
>   Scott,
>     There is a problem. Somehow you are generating a ton of new_ex*.c files and then testparse.py is crapping out on them?
>     I see some weird stuff with these files but cannot tell when they are made and why they exist.
> config/gmakegentest.py:      #if not exfile.startswith("new_"+"ex"): continue
> config/testparse.py:    new_pos = sl.instream.tell()
> config/testparse.py:    block = striptest[last_pos:new_pos]
> config/testparse.py:    last_pos = new_pos
> config/testparse.py:  bn=re.sub("new_","",basename)
> config/testparse.py:  for test_file in sorted(glob.glob("new_ex*.*")):
>> On Dec 12, 2021, at 10:32 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>  Looks like it is coming from some old .c files that I had lying around that are not in the repository.
>>  I will push a commit that prints the offending file name to make the cause easier to track down in the future
>>  Barry
>>> On Dec 12, 2021, at 6:09 PM, kruger Scott <kruger at txcorp.com <mailto:kruger at txcorp.com>> wrote:
>>> I'm baffled and unable to reproduce.  Can you give me your configure.log
>>> to help reproduce?
>>> Scott
>>> On 2021-12-12 17:40, Barry Smith did write:
>>>> Scott,
>>>>   In the branch barry/2021-11-04/add-dmplex-vecghost  which was just rebased on main I get
>>>> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost
>>>> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests
>>>> Traceback (most recent call last):
>>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module>
>>>>   main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch,
>>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main
>>>>   dataDict=pEx.walktree(os.path.join(pEx.srcdir))
>>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree
>>>>   self.genPetscTests(root,dirs,files,dataDict)
>>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests
>>>>   dataDict[root].update(testparse.parseTestFile(fullex,0))
>>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile
>>>>   testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
>>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests
>>>>   testnames,subdicts=parseTest(test,srcfile,verbosity)
>>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest
>>>>   if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid")
>>>> make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
>>>> How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
>>> Scott Kruger
>>> Tech-X Corporation               kruger at txcorp.com <mailto:kruger at txcorp.com>
>>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>>> Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211213/178e0fe8/attachment-0001.html>
