[petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
kruger Scott
kruger at txcorp.com
Tue Dec 14 09:29:53 CST 2021
I'm really confused. This is all legacy stuff from when we were working
on converting the old test harness to the new test harness. I agree
that it should all be cleaned out, but this functionality shouldn't be
called at the `gmakegentest.py` level.
If you look at the open statements in gmakegentest.py and testparse.py,
you'll see I'm not writing any of those files. That conversion was done
by a separate script.
Scott
On 2021-12-13 21:36, Barry Smith did write:
> If these are temporary work files could you not have them end with .c etc maybe have an extra .tmp at the end or something so they don't mess with everything if they are lying around? It is annoying to have to keep deleting them all.
> > On Dec 13, 2021, at 9:32 PM, Barry Smith <bsmith at petsc.dev> wrote:
> > Scott,
> > There is a problem. Somehow you are generating a ton of new_ex*.c files and then testparse.py is crapping out on them?
> > I see some weird stuff with these files but cannot tell when they are made and why they exist.
> > config/gmakegentest.py: #if not exfile.startswith("new_"+"ex"): continue
> > config/testparse.py: new_pos = sl.instream.tell()
> > config/testparse.py: block = striptest[last_pos:new_pos]
> > config/testparse.py: last_pos = new_pos
> > config/testparse.py: bn=re.sub("new_","",basename)
> > config/testparse.py: for test_file in sorted(glob.glob("new_ex*.*")):
> >> On Dec 12, 2021, at 10:32 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> >> Looks like it is coming from some old .c files that I had lying around that are not in the repository.
> >> I will push a commit that prints the offending file name to make the cause easier to track down in the future
> >> Barry
> >>> On Dec 12, 2021, at 6:09 PM, kruger Scott <kruger at txcorp.com <mailto:kruger at txcorp.com>> wrote:
> >>> I'm baffled and unable to reproduce. Can you give me your configure.log
> >>> to help reproduce?
> >>> Scott
> >>> On 2021-12-12 17:40, Barry Smith did write:
> >>>> Scott,
> >>>> In the branch barry/2021-11-04/add-dmplex-vecghost which was just rebased on main I get
> >>>> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost
> >>>> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests
> >>>> Traceback (most recent call last):
> >>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module>
> >>>> main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch,
> >>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main
> >>>> dataDict=pEx.walktree(os.path.join(pEx.srcdir))
> >>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree
> >>>> self.genPetscTests(root,dirs,files,dataDict)
> >>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests
> >>>> dataDict[root].update(testparse.parseTestFile(fullex,0))
> >>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile
> >>>> testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
> >>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests
> >>>> testnames,subdicts=parseTest(test,srcfile,verbosity)
> >>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest
> >>>> if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid")
> >>>> make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
> >>>> How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
> >>> Scott Kruger
> >>> Tech-X Corporation kruger at txcorp.com <mailto:kruger at txcorp.com>
> >>> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
> >>> Boulder, CO 80303 Fax: (303) 448-7756
Scott Kruger
