[petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
    Barry Smith
    bsmith at petsc.dev
    Mon Dec 13 20:32:50 CST 2021
  Scott,
    There is a problem. Somehow you are generating a ton of new_ex*.c files and then testparse.py is crapping out on them?
    I see some weird stuff with these files but cannot tell when they are made and why they exist.
config/gmakegentest.py:      #if not exfile.startswith("new_"+"ex"): continue
config/testparse.py:    new_pos = sl.instream.tell()
config/testparse.py:    block = striptest[last_pos:new_pos]
config/testparse.py:    last_pos = new_pos
config/testparse.py:  bn=re.sub("new_","",basename)
config/testparse.py:  for test_file in sorted(glob.glob("new_ex*.*")):
> On Dec 12, 2021, at 10:32 PM, Barry Smith <bsmith at petsc.dev> wrote:
>  Looks like it is coming from some old .c files that I had lying around that are not in the repository.
>  I will push a commit that prints the offending file name to make the cause easier to track down in the future
>  Barry
>> On Dec 12, 2021, at 6:09 PM, kruger Scott <kruger at txcorp.com> wrote:
>> I'm baffled and unable to reproduce.  Can you give me your configure.log
>> to help reproduce?
>> Scott
>> On 2021-12-12 17:40, Barry Smith did write:
>>> Scott,
>>>   In the branch barry/2021-11-04/add-dmplex-vecghost  which was just rebased on main I get
>>> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost
>>> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests
>>> Traceback (most recent call last):
>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module>
>>>   main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch,
>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main
>>>   dataDict=pEx.walktree(os.path.join(pEx.srcdir))
>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree
>>>   self.genPetscTests(root,dirs,files,dataDict)
>>> File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests
>>>   dataDict[root].update(testparse.parseTestFile(fullex,0))
>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile
>>>   testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests
>>>   testnames,subdicts=parseTest(test,srcfile,verbosity)
>>> File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest
>>>   if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid")
>>> make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
>>> How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
>> Scott Kruger
>> Tech-X Corporation               kruger at txcorp.com
>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>> Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211213/6221ed31/attachment.html>
