[petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
Barry Smith bsmith at petsc.dev
Sun Dec 12 21:32:07 CST 2021
  Looks like it is coming from some old .c files that I had lying around that are not in the repository.
  I will push a commit that prints the offending file name to make the cause easier to track down in the future
  Barry
> On Dec 12, 2021, at 6:09 PM, kruger Scott <kruger at txcorp.com> wrote:
> I'm baffled and unable to reproduce.  Can you give me your configure.log
> to help reproduce?
> Scott
> On 2021-12-12 17:40, Barry Smith did write:
>>  Scott,
>>    In the branch barry/2021-11-04/add-dmplex-vecghost  which was just rebased on main I get
>> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost
>> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests
>> Traceback (most recent call last):
>>  File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module>
>>    main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch,
>>  File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main
>>    dataDict=pEx.walktree(os.path.join(pEx.srcdir))
>>  File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree
>>    self.genPetscTests(root,dirs,files,dataDict)
>>  File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests
>>    dataDict[root].update(testparse.parseTestFile(fullex,0))
>>  File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile
>>    testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
>>  File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests
>>    testnames,subdicts=parseTest(test,srcfile,verbosity)
>>  File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest
>>    if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid")
>> make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
>> How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
> Scott Kruger
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
> Boulder, CO 80303                Fax:   (303) 448-7756
