[petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
    kruger Scott
    kruger at txcorp.com
    Sun Dec 12 17:09:35 CST 2021
I'm baffled and unable to reproduce.  Can you give me your configure.log
to help reproduce?
Scott
On 2021-12-12 17:40, Barry Smith did write:
>   Scott,
>     In the branch barry/2021-11-04/add-dmplex-vecghost  which was just rebased on main I get
> /usr/local/opt/python at 3.9/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost
> /usr/local/opt/python at 3.9/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests
> Traceback (most recent call last):
>   File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module>
>     main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch,
>   File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main
>     dataDict=pEx.walktree(os.path.join(pEx.srcdir))
>   File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree
>     self.genPetscTests(root,dirs,files,dataDict)
>   File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests
>     dataDict[root].update(testparse.parseTestFile(fullex,0))
>   File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile
>     testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
>   File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests
>     testnames,subdicts=parseTest(test,srcfile,verbosity)
>   File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest
>     if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid")
> make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
> How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
Scott Kruger
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
Boulder, CO 80303                Fax:   (303) 448-7756
