[petsc-dev] Hypre error on updated Perlmutter
Mark Adams
mfadams at lbl.gov
Thu Dec 9 10:21:59 CST 2021
I am getting this error. I have built this w/o hypre and the test are fine,
including the CUDA tests.
Any ideas?
I notice that the tests use -dm_mat_type aijcusparse with hypre.
08:13 nid003929 adams/fix_mat_ex5k= perlmutter:~/petsc$ make
PETSC_DIR=/global/homes/m/madams/petsc
PETSC_ARCH=arch-perlmutter-opt-nvidia-cuda check
Running check examples to verify correct installation
Using PETSC_DIR=/global/homes/m/madams/petsc and
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
1,5c1,70
< lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
< 0 SNES Function norm 0.0406612
< 1 SNES Function norm 4.12227e-06
< 2 SNES Function norm 6.098e-11
< Number of SNES iterations = 2
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: GPU error
> [0]PETSC ERROR: cuda error 46 (cudaErrorDevicesUnavailable) : all
CUDA-capable devices are busy or unavailable
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.16.1-442-gebb4a459f5
GIT Date: 2021-12-08 08:59:23 -0500
> [0]PETSC ERROR: /global/u2/m/madams/petsc/src/snes/tutorials/./ex19 on a
named nid003929 by madams Thu Dec 9 08:13:49 2021
> [0]PETSC ERROR: Configure options --CFLAGS=" -g -DLANDAU_DIM=2
-DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4 -mp=gpu" --CXXFLAGS=" -g
-DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4 -mp=gpu" --FFLAGS="
-g -mp=gpu" --with-cc=cc --with-cxx=CC --with-fc=ftn
--with-cudac=/opt/nvidia/hpc_sdk/Linux_x86_64/21.9/compilers/bin/nvcc
--with-debugging=0 --download-hypre=1 --with-cuda=1 --with-cuda-arch=80
--with-mpiexec=srun --with-batch=0 --download-p4est=1 --with-zlib=1
--with-make-np=8
--prefix=/global/cfs/projectdirs/m3904/petsc/current/perlmutter-opt-nvidia21.9
> [0]PETSC ERROR: #1 initialize() at
/global/u2/m/madams/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:70
> [0]PETSC ERROR: #2 getDevice() at
/global/u2/m/madams/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:360
> [0]PETSC ERROR: #3 PetscDeviceCreate() at
/global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:102
> [0]PETSC ERROR: #4 PetscDeviceInitializeDefaultDevice_Internal() at
/global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:266
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: GPU error
> [1]PETSC ERROR: cuda error 46 (cudaErrorDevicesUnavailable) : all
> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [1]PETSC ERROR: Petsc Development GIT revision: v3.16.1-442-gebb4a459f5
> [1]PETSC ERROR: /global/u2/m/madams/petsc/src/snes/tutorials/./ex19 on a
> [1]PETSC ERROR: Configure options --CFLAGS=" -g -DLANDAU_DIM=2
--with-make-np=8
> [1]PETSC ERROR: #1 initialize() at
> [1]PETSC ERROR: #2 getDevice() at
> [1]PETSC ERROR: #3 PetscDeviceCreate() at
> [1]PETSC ERROR: #4 PetscDeviceInitializeDefaultDevice_Internal() at
> [1]PETSC ERROR: #5 PetscDeviceInitialize() at
/global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:227
> [1]PETSC ERROR: #6 PCCreate_HYPRE() at
/global/u2/m/madams/petsc/src/ksp/pc/impls/hypre/hypre.c:2224
> [1]PETSC ERROR: #7 PCSetType() at
/global/u2/m/madams/petsc/src/ksp/pc/interface/pcset.c:84
> [1]PETSC ERROR: #8 PCSetFromOptions() at
/global/u2/m/madams/petsc/src/ksp/pc/interface/pcset.c:154
> [1]PETSC ERROR: #9 KSPSetFromOptions() at
/global/u2/m/madams/petsc/src/ksp/ksp/interface/itcl.c:356
> [1]PETSC ERROR: #10 SNESSetFromOptions() at
/global/u2/m/madams/petsc/src/snes/interface/snes.c:1113
> [1]PETSC ERROR: #11 main() at ex19.c:150
> [1]PETSC ERROR: PETSc Option Table entries:
> [1]PETSC ERROR: -da_refine 3
> [1]PETSC ERROR: -dm_mat_type aijcusparse
> [1]PETSC ERROR: -dm_vec_type cuda
> [0]PETSC ERROR: #5 PetscDeviceInitialize() at
> [0]PETSC ERROR: #6 PCCreate_HYPRE() at
> [0]PETSC ERROR: #7 PCSetType() at
> [0]PETSC ERROR: #8 PCSetFromOptions() at
> [0]PETSC ERROR: #9 KSPSetFromOptions() at
> [0]PETSC ERROR: #10 SNESSetFromOptions() at
> [0]PETSC ERROR: #11 main() at ex19.c:150
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -da_refine 3
> [0]PETSC ERROR: -dm_mat_type aijcusparse
> [0]PETSC ERROR: -dm_vec_type cuda
> [0]PETSC ERROR: -ksp_norm_type unpreconditioned
> [0]PETSC ERROR: -nox
> [0]PETSC ERROR: -nox_warning
> [0]PETSC ERROR: -pc_type hypre
> [0]PETSC ERROR: -snes_monitor_short
> [0]PETSC ERROR: -use_gpu_aware_mpi 0
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
> [1]PETSC ERROR: -ksp_norm_type unpreconditioned
> [1]PETSC ERROR: -nox
> [1]PETSC ERROR: -nox_warning
> [1]PETSC ERROR: -pc_type hypre
> [1]PETSC ERROR: -snes_monitor_short
> [1]PETSC ERROR: -use_gpu_aware_mpi 0
> [1]PETSC ERROR: ----------------End of Error Message -------send entire
> MPICH Notice [Rank 0] [job id 832277.2] [Thu Dec 9 08:13:50 2021]
[nid003929] - Abort(97) (rank 0 in comm 0): application called
MPI_Abort(MPI_COMM_WORLD, 97) - process 0
> aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 97) - process 0
> MPICH Notice [Rank 1] [job id 832277.2] [Thu Dec 9 08:13:50 2021]
[nid003929] - Abort(97) (rank 1 in comm 0): application called
MPI_Abort(MPI_COMM_WORLD, 97) - process 1
> aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 97) - process 1
> srun: error: nid003929: task 1: Exited with exit code 255
> srun: launch/slurm: _step_signal: Terminating StepId=832277.2
> slurmstepd: error: *** STEP 832277.2 ON nid003929 CANCELLED AT
2021-12-09T16:13:50 ***
> srun: error: nid003929: task 0: Exited with exit code 255
/global/homes/m/madams/petsc/src/snes/tutorials
Possible problem with ex19 running with hypre, diffs above
C/C++ example src/snes/tutorials/ex19 run successfully with cuda
Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211209/bc22fd99/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211209/bc22fd99/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211209/bc22fd99/attachment-0003.obj>
