[petsc-dev] PETSc GPU example
Fande Kong
fdkong.jd at gmail.com
Mon Dec 6 20:04:47 CST 2021
On Mon, Dec 6, 2021 at 5:59 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 6, 2021 at 7:54 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Thanks, Matt,
>> Sorry, I still have more questions on this example. How to refine mesh to
>> make the problem larger?
>> I tried the following options, and none of them worked. I might do
>> something wrong.
>> -ex56_dm_refine 9
>> and
>> -dm_refine 4
> The mesh handling in this example does not conform to the others, but it
> appears that
> -ex56_dm_refine <k>
> should take effect at
> https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex56.c#L381
I was puzzled about this because DMSetFromOptions does not seem to trigger
-ex56_dm_refine.
I did a search, and could not find where we call " -ex56_dm_refine" in
PETSc.
I got the same result by running the following two combinations:
1) ./ex56 -log_view -snes_view -max_conv_its 3 -ex56_dm_refine 10
2) ./ex56 -log_view -snes_view -max_conv_its 3 -ex56_dm_refine 0
Fande
unless you are setting max_conv_its to 0 somehow.
> Thanks,
> Matt
>> Thanks,
>> Fande
>> On Mon, Dec 6, 2021 at 5:04 PM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Mon, Dec 6, 2021 at 7:02 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> Thanks, Matt
>>>> On Mon, Dec 6, 2021 at 4:47 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>>>> Dear PETSc team,
>>>>>> I am interested in a careful evaluation of PETSc GPU performance in
>>>>>> our INL cluster.
>>>>>> Any example in PETSc that can show GPU speedup with solving a
>>>>>> nonlinear equation?
>>>>>> I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I
>>>>>> tried that, but I could not find any speedup using the GPU. I could attach
>>>>>> some results of "log_view" later if we would like to see that.
>>>>> We should note that you will only see speedup in the solver, so that
>>>>> problem has to be pretty large. I believe Mark has good results with it.
>>>>> The assembly is still all on the CPU. I am working on this over break,
>>>>> and hope to have a CEED version of it by the new year.
>>>> Are both function and matrix assmelies on CPU? Or just the matrix
>>>> assembly?
>>> There is no GPU assembly right now.
>>> Matt
>>>> OK, I will try to check the solver part
>>>> Thanks, again
>>>> Fande
>>>>> Thanks,
>>>>> Matt
>>>>>> Appreciate any instructions/comments about running a simple PETSc GPU
>>>>>> example to get a speedup.
>>>>>> Thanks,
>>>>>> Fande
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/074bdc6f/attachment-0001.html>
