[petsc-dev] PETSc GPU example
Matthew Knepley
knepley at gmail.com
Mon Dec 6 20:27:41 CST 2021
On Mon, Dec 6, 2021 at 9:04 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> On Mon, Dec 6, 2021 at 5:59 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Dec 6, 2021 at 7:54 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Thanks, Matt,
>>> Sorry, I still have more questions on this example. How to refine mesh
>>> to make the problem larger?
>>> I tried the following options, and none of them worked. I might do
>>> something wrong.
>>> -ex56_dm_refine 9
>>> and
>>> -dm_refine 4
>> The mesh handling in this example does not conform to the others, but it
>> appears that
>> -ex56_dm_refine <k>
>> should take effect at
>> https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex56.c#L381
> I was puzzled about this because DMSetFromOptions does not seem to trigger
> -ex56_dm_refine.
> I did a search, and could not find where we call " -ex56_dm_refine" in
> PETSc.
> I got the same result by running the following two combinations:
> 1) ./ex56 -log_view -snes_view -max_conv_its 3 -ex56_dm_refine 10
> 2) ./ex56 -log_view -snes_view -max_conv_its 3 -ex56_dm_refine 0
It is refining:
nathawani/feature-1D-droplet-model
$:/PETSc3/petsc/petsc-dev/src/snes/tutorials$ ./ex56 -ex56_dm_view
-max_conv_its 1
DM Object: Mesh (ex56_) 1 MPI processes
type: plex
Mesh in 3 dimensions:
Number of 0-cells per rank: 8
Number of 1-cells per rank: 12
Number of 2-cells per rank: 6
Number of 3-cells per rank: 1
Labels:
marker: 1 strata with value/size (1 (18))
Face Sets: 6 strata with value/size (6 (1), 5 (1), 3 (1), 4 (1), 1 (1), 2
(1))
depth: 4 strata with value/size (0 (8), 1 (12), 2 (6), 3 (1))
boundary: 1 strata with value/size (1 (26))
celltype: 4 strata with value/size (7 (1), 0 (8), 4 (6), 1 (12))
Field deformation:
adjacency FEM
-max_conv_its 1 -ex56_dm_refine 3
type: plex
Number of 0-cells per rank: 729
Number of 1-cells per rank: 1944
Number of 2-cells per rank: 1728
Number of 3-cells per rank: 512
Labels:
celltype: 4 strata with value/size (0 (729), 1 (1944), 4 (1728), 7 (512))
depth: 4 strata with value/size (0 (729), 1 (1944), 2 (1728), 3 (512))
marker: 1 strata with value/size (1 (1530))
Face Sets: 6 strata with value/size (6 (225), 5 (225), 3 (225), 4 (225),
1 (225), 2 (225))
boundary: 1 strata with value/size (1 (1538))
Field deformation:
adjacency FEM
Matt
> Thanks,
> Fande
> unless you are setting max_conv_its to 0 somehow.
>> Thanks,
>> Matt
>>> Thanks,
>>> Fande
>>> On Mon, Dec 6, 2021 at 5:04 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Dec 6, 2021 at 7:02 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>>> Thanks, Matt
>>>>> On Mon, Dec 6, 2021 at 4:47 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <fdkong.jd at gmail.com>
>>>>>> wrote:
>>>>>>> Dear PETSc team,
>>>>>>> I am interested in a careful evaluation of PETSc GPU performance in
>>>>>>> our INL cluster.
>>>>>>> Any example in PETSc that can show GPU speedup with solving a
>>>>>>> nonlinear equation?
>>>>>>> I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I
>>>>>>> tried that, but I could not find any speedup using the GPU. I could attach
>>>>>>> some results of "log_view" later if we would like to see that.
>>>>>> We should note that you will only see speedup in the solver, so that
>>>>>> problem has to be pretty large. I believe Mark has good results with it.
>>>>>> The assembly is still all on the CPU. I am working on this over
>>>>>> break, and hope to have a CEED version of it by the new year.
>>>>> Are both function and matrix assmelies on CPU? Or just the matrix
>>>>> assembly?
>>>> There is no GPU assembly right now.
>>>> Matt
>>>>> OK, I will try to check the solver part
>>>>> Thanks, again
>>>>> Fande
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Appreciate any instructions/comments about running a simple PETSc
>>>>>>> GPU example to get a speedup.
>>>>>>> Thanks,
>>>>>>> Fande
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/8150e4db/attachment.html>
