[petsc-dev] PETSc GPU example
Mon Dec 6 18:59:13 CST 2021
On Mon, Dec 6, 2021 at 7:54 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Thanks, Matt,
> Sorry, I still have more questions on this example. How to refine mesh to
> make the problem larger?
> I tried the following options, and none of them worked. I might do
> something wrong.
> -ex56_dm_refine 9
> and
> -dm_refine 4
The mesh handling in this example does not conform to the others, but it
appears that
  -ex56_dm_refine <k>
should take effect at
  https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex56.c#L381
unless you are setting max_conv_its to 0 somehow.
     Matt
> Thanks,
> Fande
> On Mon, Dec 6, 2021 at 5:04 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Dec 6, 2021 at 7:02 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Thanks, Matt
>>> On Mon, Dec 6, 2021 at 4:47 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>>> Dear PETSc team,
>>>>> I am interested in a careful evaluation of PETSc GPU performance in
>>>>> our INL cluster.
>>>>> Any example in PETSc that can show GPU speedup with solving a
>>>>> nonlinear equation?
>>>>> I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I
>>>>> tried that, but I could not find any speedup using the GPU. I could attach
>>>>> some results of "log_view" later if we would like to see that.
>>>> We should note that you will only see speedup in the solver, so that
>>>> problem has to be pretty large. I believe Mark has good results with it.
>>>> The assembly is still all on the CPU. I am working on this over break,
>>>> and hope to have a CEED version of it by the new year.
>>> Are both function and matrix assmelies on CPU? Or just the matrix
>>> assembly?
>> There is no GPU assembly right now.
>>   Matt
>>> OK, I will try to check the solver part
>>> Thanks, again
>>> Fande
>>>>   Thanks,
>>>>      Matt
>>>>> Appreciate any instructions/comments about running a simple PETSc GPU
>>>>> example to get a speedup.
>>>>> Thanks,
>>>>> Fande
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/eb9168ac/attachment.html>
