[petsc-dev] PETSc GPU example
Fande Kong fdkong.jd at gmail.com
Mon Dec 6 18:54:02 CST 2021
Thanks, Matt,
Sorry, I still have more questions on this example. How to refine mesh to
make the problem larger?
I tried the following options, and none of them worked. I might do
something wrong.
-ex56_dm_refine 9
and
-dm_refine 4
Fande
On Mon, Dec 6, 2021 at 5:04 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 6, 2021 at 7:02 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Thanks, Matt
>> On Mon, Dec 6, 2021 at 4:47 PM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> Dear PETSc team,
>>>> I am interested in a careful evaluation of PETSc GPU performance in our
>>>> INL cluster.
>>>> Any example in PETSc that can show GPU speedup with solving a nonlinear
>>>> equation?
>>>> I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I
>>>> tried that, but I could not find any speedup using the GPU. I could attach
>>>> some results of "log_view" later if we would like to see that.
>>> We should note that you will only see speedup in the solver, so that
>>> problem has to be pretty large. I believe Mark has good results with it.
>>> The assembly is still all on the CPU. I am working on this over break,
>>> and hope to have a CEED version of it by the new year.
>> Are both function and matrix assmelies on CPU? Or just the matrix
>> assembly?
> There is no GPU assembly right now.
>   Matt
>> OK, I will try to check the solver part
>> Thanks, again
>> Fande
>>>   Thanks,
>>>      Matt
>>>> Appreciate any instructions/comments about running a simple PETSc GPU
>>>> example to get a speedup.
>>>> Thanks,
>>>> Fande
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/265b18bb/attachment.html>
