[petsc-dev] PETSc GPU example
Mon Dec 6 18:04:16 CST 2021
On Mon, Dec 6, 2021 at 7:02 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Thanks, Matt
> On Mon, Dec 6, 2021 at 4:47 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Dear PETSc team,
>>> I am interested in a careful evaluation of PETSc GPU performance in our
>>> INL cluster.
>>> Any example in PETSc that can show GPU speedup with solving a nonlinear
>>> equation?
>>> I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I tried
>>> that, but I could not find any speedup using the GPU. I could attach some
>>> results of "log_view" later if we would like to see that.
>> We should note that you will only see speedup in the solver, so that
>> problem has to be pretty large. I believe Mark has good results with it.
>> The assembly is still all on the CPU. I am working on this over break,
>> and hope to have a CEED version of it by the new year.
> Are both function and matrix assmelies on CPU? Or just the matrix assembly?
There is no GPU assembly right now.
  Matt
> OK, I will try to check the solver part
> Thanks, again
> Fande
>>   Thanks,
>>      Matt
>>> Appreciate any instructions/comments about running a simple PETSc GPU
>>> example to get a speedup.
>>> Thanks,
>>> Fande
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/bc501a05/attachment-0001.html>
