[petsc-dev] DMPLEX cannot support two different edges for the same two vertices, hence DMPLEX cannot?
Wed Dec 1 17:56:48 CST 2021
On Wed, Dec 1, 2021 at 6:55 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Wed, Dec 1, 2021 at 5:17 PM Abhyankar, Shrirang G <
> > shrirang.abhyankar at pnnl.gov> wrote:
> >> “You can certainly have many fields on a given edge, but I don't know
> >> what it would mean to have two edges since no topological query could
> tell
> >> the difference.”
> >> The two edges in a power grid represent two parallel power lines that
> are
> >> connected between two locations (vertices). There are line ids (stored
> in
> >> the component data) to distinguish the two lines.
> > Yes, so you can tell the difference in the function space (since
> difference
> > current passes down each one), but _topologically_ you cannot. If you put
> > duplicate cells in, then
> > some topological queries will give unexpected results, like the join of
> the
> > two vertices.
> This could be modeled with some ghost vertices. So instead of
>   a ------ b
>    \_____/
> you would set up
>   a ---o---- b
>    \___o___/
> Those ghost vertices don't have to "do" anything, but they make the edges
> topologically distinct.
> Shri, what problems might this cause?
Yes, this would work, but it looks like the multiple cells are not causing
them problems right now with the questions they are asking the mesh.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211201/d9d9fcae/attachment.html>
