[petsc-dev] DMPLEX cannot support two different edges for the same two vertices, hence DMPLEX cannot?
    Jed Brown
    jed at jedbrown.org
    Wed Dec  1 17:55:36 CST 2021
Matthew Knepley <knepley at gmail.com> writes:
> On Wed, Dec 1, 2021 at 5:17 PM Abhyankar, Shrirang G <
> shrirang.abhyankar at pnnl.gov> wrote:
>> “You can certainly have many fields on a given edge, but I don't know
>> what it would mean to have two edges since no topological query could tell
>> the difference.”
>> The two edges in a power grid represent two parallel power lines that are
>> connected between two locations (vertices). There are line ids (stored in
>> the component data) to distinguish the two lines.
> Yes, so you can tell the difference in the function space (since difference
> current passes down each one), but _topologically_ you cannot. If you put
> duplicate cells in, then
> some topological queries will give unexpected results, like the join of the
> two vertices.
This could be modeled with some ghost vertices. So instead of
  a ------ b
   \_____/
you would set up
  a ---o---- b
   \___o___/
Those ghost vertices don't have to "do" anything, but they make the edges topologically distinct.
Shri, what problems might this cause?
