[petsc-dev] help on Summit
    Mark Adams
    mfadams at lbl.gov
    Mon Aug 30 09:50:00 CDT 2021
Stefano suggested C++14 in configure. I was using C++11.
On Mon, Aug 30, 2021 at 10:46 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
>  Petsc::CUPMInterface
> @Jacob Faibussowitsch <jacob.fai at gmail.com>
> --Junchao Zhang
> On Mon, Aug 30, 2021 at 9:35 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I was running fine this AM and am bouncing between modules to help two
>> apps (ECP milestone season) at the same time and something broke. I did
>> update main and I get the same error in main and a hypre branch of
>> Stefano's.
>> I started with a clean build and checked my modules...
>> Any ideas?
>> Thanks,
>> Mark
>>        CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o
>>           CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o
>>    CUDAC.dep
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o
>>    CUDAC.dep
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o
>>    CUDAC.dep
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o
>>    CUDAC.dep
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
>>    CUDAC.dep
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o
>>    CUDAC.dep
>>        CUDAC
>> arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o
>>    CUDAC.dep
>>      CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3
>> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0):
>> multiple definition of
>> `Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking'
>> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44):
>> first defined here
>> /usr/bin/ld: link errors found, deleting executable
>> `arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3'
>> collect2: error: ld returned 1 exit status
>> gmake[3]: *** [gmakefile:113:
>> arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1
>> gmake[2]: ***
>> [/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs]
>> Error 2
>> **************************ERROR*************************************
>>   Error during compile, check
>> arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log
>>   Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to
>> petsc-maint at mcs.anl.gov
>> gmake[1]: *** [makefile:40: all] Error 1
>> make: *** [GNUmakefile:9: all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/61dfaef8/attachment.html>
