[petsc-dev] help on Summit
    Junchao Zhang
    junchao.zhang at gmail.com
    Mon Aug 30 09:46:03 CDT 2021
 Petsc::CUPMInterface
@Jacob Faibussowitsch <jacob.fai at gmail.com>
--Junchao Zhang
On Mon, Aug 30, 2021 at 9:35 AM Mark Adams <mfadams at lbl.gov> wrote:
> I was running fine this AM and am bouncing between modules to help two
> apps (ECP milestone season) at the same time and something broke. I did
> update main and I get the same error in main and a hypre branch of
> Stefano's.
> I started with a clean build and checked my modules...
> Any ideas?
> Thanks,
> Mark
>        CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o
>           CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o
>    CUDAC.dep
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o
>    CUDAC.dep
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o
>    CUDAC.dep
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o
>    CUDAC.dep
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
>    CUDAC.dep
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o
>    CUDAC.dep
>        CUDAC
> arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o
>    CUDAC.dep
>      CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3
> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0):
> multiple definition of
> `Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking'
> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44):
> first defined here
> /usr/bin/ld: link errors found, deleting executable
> `arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3'
> collect2: error: ld returned 1 exit status
> gmake[3]: *** [gmakefile:113:
> arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1
> gmake[2]: ***
> [/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs]
> Error 2
> **************************ERROR*************************************
>   Error during compile, check
> arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log
>   Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov
> gmake[1]: *** [makefile:40: all] Error 1
> make: *** [GNUmakefile:9: all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/42efe412/attachment.html>
