[petsc-dev] help on Summit
    Mark Adams
    mfadams at lbl.gov
    Mon Aug 30 10:12:53 CDT 2021
No luck with C++14
       CUDAC
arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o
   CUDAC.dep
     CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3
arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0):
multiple definition of
`Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking'
arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44):
first defined here
/usr/bin/ld: link errors found, deleting executable
`arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3'
collect2: error: ld returned 1 exit status
gmake[3]: *** [gmakefile:113:
arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1
gmake[2]: ***
[/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs]
Error 2
**************************ERROR*************************************
  Error during compile, check
arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log
  Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov
gmake[1]: *** [makefile:40: all] Error 1
On Mon, Aug 30, 2021 at 10:50 AM Mark Adams <mfadams at lbl.gov> wrote:
> Stefano suggested C++14 in configure. I was using C++11.
> On Mon, Aug 30, 2021 at 10:46 AM Junchao Zhang <junchao.zhang at gmail.com>
>> @Jacob Faibussowitsch <jacob.fai at gmail.com>
>> --Junchao Zhang
>> On Mon, Aug 30, 2021 at 9:35 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> I was running fine this AM and am bouncing between modules to help two
>>> apps (ECP milestone season) at the same time and something broke. I did
>>> update main and I get the same error in main and a hypre branch of
>>> Stefano's.
>>> I started with a clean build and checked my modules...
>>> Any ideas?
>>> Thanks,
>>> Mark
>>>        CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o
>>>           CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o
>>>        CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o
>>>    CUDAC.dep
>>>        CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o
>>>    CUDAC.dep
>>>        CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o
>>>    CUDAC.dep
>>>        CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o
>>>    CUDAC.dep
>>>        CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
>>>    CUDAC.dep
>>>        CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o
>>>    CUDAC.dep
>>>        CUDAC
>>>    CUDAC.dep
>>> first defined here
>>> gmake[2]: ***
>>> Error 2
>>> make: *** [GNUmakefile:9: all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/43b1c695/attachment-0001.html>
