[petsc-dev] building on Spock
Mark Adams mfadams at lbl.gov
Fri Aug 13 17:17:06 CDT 2021
I seem to be getting Kokkos includes in my install but there is no kokkos
in the configure and I started with a clean PETSc arch directory and
install directory. Does this make sense?
18:12 main= /gpfs/alpine/csc314/scratch/adams/petsc$ ll
/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray/include/
 | grep -i kokko
-rw-rw-r-- 1 adams adams    7074 May 27 06:57 petscdmda_kokkos.hpp
-rw-rw-r-- 1 adams adams    1636 May 27 06:57 petscvec_kokkos.hpp
On Fri, Aug 13, 2021 at 2:27 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, Aug 13, 2021 at 2:01 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Aug 13, 2021 at 1:49 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> I was building on Spock a few weeks ago, but am getting these errors
>>> now.
>>> I have a setup with this environment and get this error.
>>> Any ideas?
>> Here is the error:
>> Executing: cc  -o /tmp/petsc-6izfgpkr/config.setCompilers/conftest
>> -L/opt/rocm-4.2.0/lib -lhsa-runtime64 -L${ROCM_PATH}/lib -lamdhip64
>> -lhsa-runtime64  /tmp/petsc-6izfgpkr/config.setCompilers/conftest.o
>> Possible ERROR while running linker: exit code 1
>> stderr:
>> ld.lld: error: unable to find library -lmpi_gtl_hsa
>> clang-12: error: linker command failed with exit code 1 (use -v to see
>> invocation)
>> Linker output before filtering:
>> invocation)
>> Linker output after filtering:
>> invocation):
>>           Error testing C compiler: Cannot compile/link C with cc.
>>             Deleting "CC"
>> That -l look like it is put in directly by 'cc'. How does anything work
>> on that machine?
> It looks like this comes from an env variable that I have:
>     export PE_MPICH_GTL_LIBS_amd_gfx908="-lmpi_gtl_hsa"
>>    Matt
>>> Thanks,
>>> Mark
>>>     module load craype-accel-amd-gfx908
>>>     module load rocm
>>>     module load emacs
>>>     module load zlib
>>>     module load autoconf automake libtool
>>>     ## These must be set before compiling so the executable picks up GTL
>>>     export
>>> PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib"
>>>     ## These must be set before running
>>>     export MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0
>>>     export MPICH_GPU_SUPPORT_ENABLED=1
>>>     export MPICH_SMP_SINGLE_COPY_MODE=CMA
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210813/b729150c/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210813/b729150c/attachment-0001.obj>
