[petsc-dev] building on Spock
Mark Adams mfadams at lbl.gov
Fri Aug 13 13:27:59 CDT 2021
On Fri, Aug 13, 2021 at 2:01 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 13, 2021 at 1:49 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I was building on Spock a few weeks ago, but am getting these errors now.
>> I have a setup with this environment and get this error.
>> Any ideas?
> Here is the error:
> Executing: cc  -o /tmp/petsc-6izfgpkr/config.setCompilers/conftest
> -L/opt/rocm-4.2.0/lib -lhsa-runtime64 -L${ROCM_PATH}/lib -lamdhip64
> -lhsa-runtime64  /tmp/petsc-6izfgpkr/config.setCompilers/conftest.o
> Possible ERROR while running linker: exit code 1
> stderr:
> ld.lld: error: unable to find library -lmpi_gtl_hsa
> clang-12: error: linker command failed with exit code 1 (use -v to see
> invocation)
> Linker output before filtering:
> invocation)
> Linker output after filtering:
> invocation):
>           Error testing C compiler: Cannot compile/link C with cc.
>             Deleting "CC"
> That -l look like it is put in directly by 'cc'. How does anything work on
> that machine?
It looks like this comes from an env variable that I have:
    export PE_MPICH_GTL_LIBS_amd_gfx908="-lmpi_gtl_hsa"
>    Matt
>> Thanks,
>> Mark
>>     module load craype-accel-amd-gfx908
>>     module load rocm
>>     module load emacs
>>     module load zlib
>>     module load autoconf automake libtool
>>     ## These must be set before compiling so the executable picks up GTL
>>     export
>> PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib"
>>     ## These must be set before running
>>     export MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0
>>     export MPICH_GPU_SUPPORT_ENABLED=1
>>     export MPICH_SMP_SINGLE_COPY_MODE=CMA
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210813/489698ac/attachment.html>
