[petsc-dev] building on Spock
Junchao Zhang junchao.zhang at gmail.com
Fri Aug 13 20:39:28 CDT 2021
Yes, the two files are just petsc headers.
--Junchao Zhang
On Fri, Aug 13, 2021 at 5:17 PM Mark Adams <mfadams at lbl.gov> wrote:
> I seem to be getting Kokkos includes in my install but there is no kokkos
> in the configure and I started with a clean PETSc arch directory and
> install directory. Does this make sense?
> 18:12 main= /gpfs/alpine/csc314/scratch/adams/petsc$ ll
> /gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray/include/
>  | grep -i kokko
> -rw-rw-r-- 1 adams adams    7074 May 27 06:57 petscdmda_kokkos.hpp
> -rw-rw-r-- 1 adams adams    1636 May 27 06:57 petscvec_kokkos.hpp
> On Fri, Aug 13, 2021 at 2:27 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Fri, Aug 13, 2021 at 2:01 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Aug 13, 2021 at 1:49 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I was building on Spock a few weeks ago, but am getting these errors
>>>> now.
>>>> I have a setup with this environment and get this error.
>>>> Any ideas?
>>> Here is the error:
>>> Executing: cc  -o /tmp/petsc-6izfgpkr/config.setCompilers/conftest
>>> -L/opt/rocm-4.2.0/lib -lhsa-runtime64 -L${ROCM_PATH}/lib -lamdhip64
>>> -lhsa-runtime64  /tmp/petsc-6izfgpkr/config.setCompilers/conftest.o
>>> Possible ERROR while running linker: exit code 1
>>> stderr:
>>> ld.lld: error: unable to find library -lmpi_gtl_hsa
>>> clang-12: error: linker command failed with exit code 1 (use -v to see
>>> invocation)
>>> Linker output before filtering:
>>> invocation)
>>> Linker output after filtering:
>>> invocation):
>>>           Error testing C compiler: Cannot compile/link C with cc.
>>>             Deleting "CC"
>>> That -l look like it is put in directly by 'cc'. How does anything work
>>> on that machine?
>> It looks like this comes from an env variable that I have:
>>     export PE_MPICH_GTL_LIBS_amd_gfx908="-lmpi_gtl_hsa"
>>>    Matt
>>>> Thanks,
>>>> Mark
>>>>     module load craype-accel-amd-gfx908
>>>>     module load rocm
>>>>     module load emacs
>>>>     module load zlib
>>>>     module load autoconf automake libtool
>>>>     ## These must be set before compiling so the executable picks up GTL
>>>>     export
>>>> PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib"
>>>>     ## These must be set before running
>>>>     export MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0
>>>>     export MPICH_GPU_SUPPORT_ENABLED=1
>>>>     export MPICH_SMP_SINGLE_COPY_MODE=CMA
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210813/abec6f40/attachment.html>
