[petsc-dev] empty space on left side of website pages
Karl Rupp rupp at iue.tuwien.ac.at
Tue Apr 27 08:33:00 CDT 2021
such adjustments should not need a direct modification of the theme. One
can just override the CSS settings in custom CSS files instead:
  https://docs.readthedocs.io/en/stable/guides/adding-custom-css.html
The benefit of such an approach is that all future updates of the theme
will continue to work. Plus, one has all CSS-tweaks neatly collected in
a small file (ideally just a few lines).
Best regards,
Karli
On 4/26/21 8:58 AM, Patrick Sanan wrote:
> As far as I know (which isn't very far, with web stuff), changing things
> on that level requires somehow getting into CSS.
> For instance, you can see what it looks like with other widths directly
> from Firefox (fun, didn't know you could do this):
> - go to the page
> - hit F12
> - click around on the left to find the <div> that corresponds to the
> part you care about
> - look in the middle column to find the piece of CSS that's controlling
> things (here, something called .col-md-3)
> - edit the CSS - in attached screenshot I change the max width of that
> sidebar to 5%.
> But, I want to avoid having to do things on the level of CSS and HTML -
> I think that should be done as a collective effort in maintaining the
> theme (and Sphinx itself).
> If we really care enough about the width of that sidebar, we'll create a
> fork of the theme, add a setting for it, and try to get it merged to the
> theme's release branch.
>> Am 23.04.2021 um 23:12 schrieb Barry Smith <bsmith at petsc.dev
>> <mailto:bsmith at petsc.dev>>:
>>    Thanks. Even if we just leave it is there a way to make it a little
>> "skinnier", it seems very wide in my default browser.
>>> On Apr 23, 2021, at 1:08 PM, Patrick Sanan <patrick.sanan at gmail.com
>>> <mailto:patrick.sanan at gmail.com>> wrote:
>>> It is possible to put things there, as in this link which is both
>>> documentation and example:
>>> https://pydata-sphinx-theme.readthedocs.io/en/latest/user_guide/sections.html#the-left-sidebar
>>> <https://pydata-sphinx-theme.readthedocs.io/en/latest/user_guide/sections.html#the-left-sidebar>
>>> Other projects using this theme have the mostly-empty left sidebar:
>>> https://numpy.org/doc/stable/ <https://numpy.org/doc/stable/>
>>> https://jupyter.readthedocs.io/en/latest/
>>> <https://jupyter.readthedocs.io/en/latest/>
>>> (They also have fancier landing pages, though, which we have been
>>> discussing).
>>> It goes away on mobile devices or small windows, at least.
>>>> Am 23.04.2021 um 19:21 schrieb Barry Smith <bsmith at petsc.dev
>>>>   There is a lot of empty space on the left side of the website
>>>> pages; under the Search slot.  Does this empty left side need to be
>>>> so large, seems to waste a lot of the screen?
>>>>   Barry
