[petsc-dev] empty space on left side of website pages
Jed Brown jed at jedbrown.org
Mon Apr 26 16:03:57 CDT 2021
Generic use of sphinx-panels doesn't spread out into the sidebar, but panels with some diagrams/figures would still improve the landing page.
https://pandas.pydata.org/docs/index.html
Patrick Sanan <patrick.sanan at gmail.com> writes:
> Part of the reason that the huge, empty sidebar looks so bad is that it's on the front page - in the interests of simplicity and focusing on getting the build stable, I haven't been focusing on it, but there is still discussion to be had about whether and how to make a prettier front/landing page.
>> Am 26.04.2021 um 21:05 schrieb Jed Brown <jed at jedbrown.org>:
>> The sphinx-pydata-theme has great mobile support and lots of development energy behind it. I don't want to switch themes again based on a sidebar sizing concern. If the sidebar width is super important, we can adjust the CSS. The standard CSS has this, which I think is what we'd want to adjust.
>> .container-xl {
>>  max-width: 1400px
>> Scott Kruger <kruger at txcorp.com> writes:
>>> Rather than have us edit the CSS, perhaps just getting people to agree
>>> to a different theme:
>>> https://sphinx-themes.org/
>>> I think alabaster, aiohttp, cloud_sptheme, ...  meet Barry's complaint.
>>> There is a lot to like on the kotti_docs_theme for example although the
>>> bar is on the right instead of the left.
>>> Scott
>>> On 2021-04-26 08:58, Patrick Sanan did write:
>>>> As far as I know (which isn't very far, with web stuff), changing things on that level requires somehow getting into CSS.
>>>> For instance, you can see what it looks like with other widths directly from Firefox (fun, didn't know you could do this):
>>>> - go to the page
>>>> - hit F12
>>>> - click around on the left to find the <div> that corresponds to the part you care about
>>>> - look in the middle column to find the piece of CSS that's controlling things (here, something called .col-md-3)
>>>> - edit the CSS - in attached screenshot I change the max width of that sidebar to 5%.
>>>> But, I want to avoid having to do things on the level of CSS and HTML - I think that should be done as a collective effort in maintaining the theme (and Sphinx itself).
>>>> If we really care enough about the width of that sidebar, we'll create a fork of the theme, add a setting for it, and try to get it merged to the theme's release branch.
>>>>> Am 23.04.2021 um 23:12 schrieb Barry Smith <bsmith at petsc.dev>:
>>>>>   Thanks. Even if we just leave it is there a way to make it a little "skinnier", it seems very wide in my default browser.
>>>>>> On Apr 23, 2021, at 1:08 PM, Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>> wrote:
>>>>>> It is possible to put things there, as in this link which is both documentation and example:
>>>>>> https://pydata-sphinx-theme.readthedocs.io/en/latest/user_guide/sections.html#the-left-sidebar <https://pydata-sphinx-theme.readthedocs.io/en/latest/user_guide/sections.html#the-left-sidebar>
>>>>>> Other projects using this theme have the mostly-empty left sidebar:
>>>>>> https://numpy.org/doc/stable/ <https://numpy.org/doc/stable/>
>>>>>> https://jupyter.readthedocs.io/en/latest/ <https://jupyter.readthedocs.io/en/latest/>
>>>>>> (They also have fancier landing pages, though, which we have been discussing).
>>>>>> It goes away on mobile devices or small windows, at least.
>>>>>>> Am 23.04.2021 um 19:21 schrieb Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>:
>>>>>>>  There is a lot of empty space on the left side of the website pages; under the Search slot.  Does this empty left side need to be so large, seems to waste a lot of the screen?
>>>>>>>  Barry
>>> Scott Kruger
>>> Tech-X Corporation               kruger at txcorp.com
>>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>>> Boulder, CO 80303                Fax:   (303) 448-7756
