[petsc-dev] empty space on left side of website pages
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Tue Apr 27 08:42:31 CDT 2021
One of the primary goals of the new documentation was that maintenance of docs be as streamlined as possible, i.e. through a single API/language/interface. A new dev should have to learn the absolute bare minimum possible to be able to make changes to documentation, so while CSS add-ons is on face less code diff and simpler to implement right now, it doesn’t fit with the single API doctrine.
Best regards,
(Jacob Fai - booss - oh - vitch)
> On Apr 27, 2021, at 09:33, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi,
> such adjustments should not need a direct modification of the theme. One can just override the CSS settings in custom CSS files instead:
> https://docs.readthedocs.io/en/stable/guides/adding-custom-css.html
> The benefit of such an approach is that all future updates of the theme will continue to work. Plus, one has all CSS-tweaks neatly collected in a small file (ideally just a few lines).
> Best regards,
> Karli
> On 4/26/21 8:58 AM, Patrick Sanan wrote:
>> As far as I know (which isn't very far, with web stuff), changing things on that level requires somehow getting into CSS.
>> For instance, you can see what it looks like with other widths directly from Firefox (fun, didn't know you could do this):
>> - go to the page
>> - hit F12
>> - click around on the left to find the <div> that corresponds to the part you care about
>> - look in the middle column to find the piece of CSS that's controlling things (here, something called .col-md-3)
>> - edit the CSS - in attached screenshot I change the max width of that sidebar to 5%.
>> But, I want to avoid having to do things on the level of CSS and HTML - I think that should be done as a collective effort in maintaining the theme (and Sphinx itself).
>> If we really care enough about the width of that sidebar, we'll create a fork of the theme, add a setting for it, and try to get it merged to the theme's release branch.
>>> Am 23.04.2021 um 23:12 schrieb Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>:
>>>    Thanks. Even if we just leave it is there a way to make it a little "skinnier", it seems very wide in my default browser.
>>>> On Apr 23, 2021, at 1:08 PM, Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>> wrote:
>>>> It is possible to put things there, as in this link which is both documentation and example:
>>>> https://pydata-sphinx-theme.readthedocs.io/en/latest/user_guide/sections.html#the-left-sidebar <https://pydata-sphinx-theme.readthedocs.io/en/latest/user_guide/sections.html#the-left-sidebar>
>>>> Other projects using this theme have the mostly-empty left sidebar:
>>>> https://numpy.org/doc/stable/ <https://numpy.org/doc/stable/>
>>>> https://jupyter.readthedocs.io/en/latest/ <https://jupyter.readthedocs.io/en/latest/>
>>>> (They also have fancier landing pages, though, which we have been discussing).
>>>> It goes away on mobile devices or small windows, at least.
>>>>> Am 23.04.2021 um 19:21 schrieb Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>:
>>>>>   There is a lot of empty space on the left side of the website pages; under the Search slot.  Does this empty left side need to be so large, seems to waste a lot of the screen?
>>>>>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210427/fd176668/attachment-0001.html>
