[petsc-dev] Error on Fugaku
Mark Adams
mfadams at lbl.gov
Wed Apr 14 12:45:31 CDT 2021
If you feel inspired you could try Kokkos :||
I am in a parking lot waiting for my daughter but can try this when I get
home,
Thanks again,
On Wed, Apr 14, 2021 at 1:33 PM Satish Balay <balay at mcs.anl.gov> wrote:
> I think I allocated a single node - and did the build on it.
> Now I'm getting an error - don't know what changed..
> login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L
> "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600"
> [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
> Ok - the following worked..
> [INFO] PJM 0000 pjsub Job 6301572 submitted.
> [INFO] PJM 0081 .connected.
> [INFO] PJM 0082 pjsub Interactive job 6301572 started.
> [a04201 at j31-3110s petsc]$
> Ok - trying this build now.
> [a04201 at j31-3110s petsc]$ cat
> ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py
> #!/usr/bin/python3
> if __name__ == '__main__':
> import sys
> import os
> sys.path.insert(0, os.path.abspath('config'))
> import configure
> configure_options = [
> '--with-blaslapack-lib=-lfjlapack',
> '--with-debugging=0',
> 'CC=mpifcc',
> 'CXX=mpiFCC',
> 'FC=mpifrt',
> 'PETSC_ARCH=arch-arm',
> configure.petsc_configure(configure_options)
> --download-p4est --download-zlib
> <snip>
> p4est:
> Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include
> Library: -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib
> -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
> Ok - this worked for me.
> Satish
> On Wed, 14 Apr 2021, Mark Adams wrote:
> > Do you recall what nodes you use to build on a "compute" node, to avoid
> > cross compilation?
> > On Wed, Apr 14, 2021 at 12:08 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > looks like p4est cannot be cross-compiled.
> > > Satish
> > > > I get this error with p4est on Fugaku.
> > > > It is a Fortran error. Odd.
> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210414/315e6fc8/attachment.html>
