[petsc-dev] Error on Fugaku
    Mark Adams
    mfadams at lbl.gov
    Wed Apr 14 13:34:07 CDT 2021
I have this building now.
Do you know anything about OpenMP?
I can add --with-openmp
That should get Kokkos to be made with OpenMP.
Should PETSc deal with the compilers correctly?
On Wed, Apr 14, 2021 at 1:45 PM Mark Adams <mfadams at lbl.gov> wrote:
> Thanks,
> If you feel inspired you could try Kokkos :||
> I am in a parking lot waiting for my daughter but can try this when I get
> home,
> Thanks again,
> Mark
> On Wed, Apr 14, 2021 at 1:33 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> I think I allocated a single node - and did the build on it.
>> Now I'm getting an error - don't know what changed..
>> login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L
>> "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600"
>> [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
>> Ok - the following worked..
>> [INFO] PJM 0000 pjsub Job 6301572 submitted.
>> [INFO] PJM 0081 .connected.
>> [INFO] PJM 0082 pjsub Interactive job 6301572 started.
>> [a04201 at j31-3110s petsc]$
>> Ok - trying this build now.
>> [a04201 at j31-3110s petsc]$ cat
>> ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py
>> #!/usr/bin/python3
>> if __name__ == '__main__':
>>   import sys
>>   import os
>>   sys.path.insert(0, os.path.abspath('config'))
>>   import configure
>>   configure_options = [
>>     '--with-blaslapack-lib=-lfjlapack',
>>     '--with-debugging=0',
>>     'CC=mpifcc',
>>     'CXX=mpiFCC',
>>     'FC=mpifrt',
>>     'PETSC_ARCH=arch-arm',
>>   configure.petsc_configure(configure_options)
>> --download-p4est --download-zlib
>> <snip>
>> p4est:
>>   Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include
>>   Library:  -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib
>> -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
>> Ok - this worked for me.
>> Satish
>> On Wed, 14 Apr 2021, Mark Adams wrote:
>> > Do you recall what nodes you use to build on a "compute" node, to avoid
>> > cross compilation?
>> > On Wed, Apr 14, 2021 at 12:08 PM Satish Balay <balay at mcs.anl.gov>
>> wrote:
>> > > looks like p4est cannot be cross-compiled.
>> > > Satish
>> > > > I get this error with p4est on Fugaku.
>> > > > It is a Fortran error. Odd.
>> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210414/fc7faa22/attachment-0001.html>
