[petsc-dev] Error on Fugaku
Satish Balay
balay at mcs.anl.gov
Wed Apr 14 12:33:04 CDT 2021
I think I allocated a single node - and did the build on it.
Now I'm getting an error - don't know what changed..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600"
[ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
Ok - the following worked..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=600"
[INFO] PJM 0000 pjsub Job 6301572 submitted.
[INFO] PJM 0081 .connected.
[INFO] PJM 0082 pjsub Interactive job 6301572 started.
[a04201 at j31-3110s petsc]$
Ok - trying this build now.
[a04201 at j31-3110s petsc]$ cat ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py
#!/usr/bin/python3
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--with-blaslapack-lib=-lfjlapack',
'--with-debugging=0',
'CC=mpifcc',
'CXX=mpiFCC',
'FC=mpifrt',
'PETSC_ARCH=arch-arm',
configure.petsc_configure(configure_options)
[a04201 at j31-3110s petsc]$ ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py --download-p4est --download-zlib
<snip>
p4est:
Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include
Library: -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
Ok - this worked for me.
Satish
On Wed, 14 Apr 2021, Mark Adams wrote:
> Do you recall what nodes you use to build on a "compute" node, to avoid
> cross compilation?
> On Wed, Apr 14, 2021 at 12:08 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > looks like p4est cannot be cross-compiled.
> > Satish
> > > I get this error with p4est on Fugaku.
> > > It is a Fortran error. Odd.
> > > Mark
