[petsc-dev] DMNetwork static sizing
    Matthew Knepley
    knepley at gmail.com
    Wed Apr  7 06:08:19 CDT 2021
On Tue, Apr 6, 2021 at 7:44 PM Abhyankar, Shrirang G <
shrirang.abhyankar at pnnl.gov> wrote:
> Hong,
>   It was just to keep things simple. We can have an API (and a run-time
> option) for setting the max. number of components instead of a configure
> option. I can work on making this change.
I would advocate just carrying the size of those arrays in the struct. That
way it can be completely flexible, and you can just check at runtime if
there is a chance of out of bounds indexing.
    Matt
> Thanks,
> Shri
> *From: *petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of PETSc
> Development <petsc-dev at mcs.anl.gov>
> *Reply-To: *"Zhang, Hong" <hzhang at mcs.anl.gov>
> *Date: *Tuesday, April 6, 2021 at 4:46 PM
> *To: *Matthew Knepley <knepley at gmail.com>, PETSc Development <
> *Cc: *"Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>
> *Subject: *Re: [petsc-dev] DMNetwork static sizing
> Shri,
> You designed this approach. Is it intended or out of implementation
> convenience at the time?
> Hong
> *From:* petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Matthew
> *Sent:* Monday, April 5, 2021 5:47 AM
> *To:* PETSc <petsc-dev at mcs.anl.gov>
> *Subject:* [petsc-dev] DMNetwork static sizing
> Dowe really need a configure time constant for
> struct _p_DMNetworkComponentHeader {
>   PetscInt index;    /* index for user input global edge and vertex */
>   PetscInt subnetid; /* Id for subnetwork */
>   PetscInt ndata;    /* number of components */
>   PetscInt size[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
>   PetscInt key[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
>   PetscInt offset[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
>   PetscInt nvar[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT]; /* Number
> of variables */
>   PetscInt offsetvarrel[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT]; /*
> offset from the first variable of the network point */
> } PETSC_ATTRIBUTEALIGNED(PetscMax(sizeof(double),sizeof(PetscScalar)));
> Can't we just allocate this struct when needed and carry the size along?
> This design seem to go against the rest of what we do in PETSc?
>   Thanks,
>      Matt
> experiments lead.
> -- Norbert Wiener
> <https://gcc02.safelinks.protection.outlook.com/?url=http:%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cshrirang.abhyankar%40pnnl.gov%7C939ff6f678d44ac6f15408d8f9457203%7Cd6faa5f90ae240338c0130048a38deeb%7C0%7C0%7C637533423968218909%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=poe0pJ2JhmdHmV5%2BzkkNNzENa4tAV0rqfU%2BHXtvF1nQ%3D&reserved=0>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210407/75da9e0f/attachment.html>
