[petsc-dev] Petsc: Error code 1
    Chen Gang
    569615491 at qq.com
    Mon Apr  5 22:43:13 CDT 2021
Dear Professor,
I was running the petsc test using
# make all test -j
AND I got the error code 1 message of six examples.
What is error code 1 and how can location the error.
I went the exactly file and make, it seems the examples can be running well. I don't understand what is error code 1.
The below is the summary.
Looking forward to hearing you!
#   Summary
# FAILED diff-tao_complementarity_tutorials-blackscholes_2 diff-tao_bound_tutorials-plate2f_2 diff-tao_complementarity_tutorials-blackscholes_6 diff-tao_bound_tutorials-plate2f_1 diff-vec_is_is_tutorials-ex2f_1 diff-tao_complementarity_tutorials-blackscholes_7
# success 7544/9528 tests (79.2%)
# failed 6/9528 tests (0.1%)
# todo 225/9528 tests (2.4%)
# skip 1753/9528 tests (18.4%)
# Wall clock time for tests: 1552 sec
# Approximate CPU time (not incl. build time): 106566.87999999993 sec
# To rerun failed tests:
#     /opt/rh/devtoolset-9/root/usr/bin/gmake -f gmakefile test test-fail=1
# Timing summary (actual test time / total CPU time):
#   mat_tests-ex44_mpiio_15: 220.10 sec / 221.33 sec
#   mat_tests-ex44_stdio_15: 220.07 sec / 221.15 sec
#   dm_impls_stag_tests-ex1_basic_2: 209.29 sec / 211.16 sec
#   dm_tutorials-ex15_3: 177.42 sec / 178.46 sec
#   dm_impls_stag_tutorials-ex6_4: 177.10 sec / 178.31 sec
Best,
Gang Chen
Sichuan Univertsity,
School of Mathematics,
Chengdu, China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/d1cc9394/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/d1cc9394/attachment-0001.obj>
