[petsc-dev] DMNetwork static sizing
Abhyankar, Shrirang G shrirang.abhyankar at pnnl.gov
Tue Apr 6 18:44:26 CDT 2021
Hong,
  It was just to keep things simple. We can have an API (and a run-time option) for setting the max. number of components instead of a configure option. I can work on making this change.
Shri
From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of PETSc Development <petsc-dev at mcs.anl.gov>
Reply-To: "Zhang, Hong" <hzhang at mcs.anl.gov>
Date: Tuesday, April 6, 2021 at 4:46 PM
To: Matthew Knepley <knepley at gmail.com>, PETSc Development <petsc-dev at mcs.anl.gov>
Cc: "Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>
Subject: Re: [petsc-dev] DMNetwork static sizing
Shri,
You designed this approach. Is it intended or out of implementation convenience at the time?
Hong
From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Matthew Knepley <knepley at gmail.com>
Sent: Monday, April 5, 2021 5:47 AM
To: PETSc <petsc-dev at mcs.anl.gov>
Subject: [petsc-dev] DMNetwork static sizing
Dowe really need a configure time constant for
struct _p_DMNetworkComponentHeader {
  PetscInt index;    /* index for user input global edge and vertex */
  PetscInt subnetid; /* Id for subnetwork */
  PetscInt ndata;    /* number of components */
  PetscInt size[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
  PetscInt key[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
  PetscInt offset[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
  PetscInt nvar[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT]; /* Number of variables */
  PetscInt offsetvarrel[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT]; /* offset from the first variable of the network point */
} PETSC_ATTRIBUTEALIGNED(PetscMax(sizeof(double),sizeof(PetscScalar)));
Can't we just allocate this struct when needed and carry the size along?
This design seem to go against the rest of what we do in PETSc?
     Matt
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://gcc02.safelinks.protection.outlook.com/?url=http:%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cshrirang.abhyankar%40pnnl.gov%7C939ff6f678d44ac6f15408d8f9457203%7Cd6faa5f90ae240338c0130048a38deeb%7C0%7C0%7C637533423968218909%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=poe0pJ2JhmdHmV5%2BzkkNNzENa4tAV0rqfU%2BHXtvF1nQ%3D&reserved=0>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/94149626/attachment.html>
