[petsc-dev] DMNetwork static sizing
Zhang, Hong
hzhang at mcs.anl.gov
Tue Apr 6 16:46:13 CDT 2021
Shri,
You designed this approach. Is it intended or out of implementation convenience at the time?
Hong
From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Matthew Knepley <knepley at gmail.com>
Sent: Monday, April 5, 2021 5:47 AM
To: PETSc <petsc-dev at mcs.anl.gov>
Subject: [petsc-dev] DMNetwork static sizing
Dowe really need a configure time constant for
struct _p_DMNetworkComponentHeader {
PetscInt index; /* index for user input global edge and vertex */
PetscInt subnetid; /* Id for subnetwork */
PetscInt ndata; /* number of components */
PetscInt size[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
PetscInt key[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
PetscInt offset[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT];
PetscInt nvar[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT]; /* Number of variables */
PetscInt offsetvarrel[PETSC_DMNETWORK_MAXIMUM_COMPONENTS_PER_POINT]; /* offset from the first variable of the network point */
} PETSC_ATTRIBUTEALIGNED(PetscMax(sizeof(double),sizeof(PetscScalar)));
Can't we just allocate this struct when needed and carry the size along?
This design seem to go against the rest of what we do in PETSc?
Matt
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/ee6848a6/attachment.html>
