[petsc-dev] Regression in manualpages generation?
Tue Apr 6 10:03:18 CDT 2021
https://www.mcs.anl.gov/petsc/petsc-current/ is from petsc-3.15.0 -
and is normally gets updated with the next patch release - i.e
petsc-3.15.1. [ok - I'll update now with current release snapshot]
Also dev pages should get updated daily [there is a bug here
that I should fix]
With the latest snapshots - both the pages appear to list MatGetRow_MPIDense
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html
https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatGetRow.html
Satish
On Tue, 6 Apr 2021, Pierre Jolivet wrote:
> Thanks for the recent MR.
> This sadly only partially addresses the issue.
> https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html <https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html> correctly has MatGetRow_MPIDense while https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html> hasn’t.
> Thanks,
> Pierre
> > On 3 Apr 2021, at 1:24 PM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> > I think this was likely a non-portable regex that was being used to match the function signatures,
> > causing it to miss anything with an internal "s" in the function name. Here's a quick fix for the release branch:
> > https://gitlab.com/petsc/petsc/-/merge_requests/3813 <https://gitlab.com/petsc/petsc/-/merge_requests/3813>
> > (This sort of thing will become easier to work with, soon, as we'll have an automated doc build which can be examined for each MR.)
> > P.S. nice email address!
> >> Am 03.04.2021 um 11:19 schrieb Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>>:
> >> That isn't expected - thanks for pointing this out! I can reproduce locally so will take a look.
> >>> Am 03.04.2021 um 11:10 schrieb Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>:
> >>> Hello,
> >>> https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html <https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html> lists available implementations while https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html <https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html> doesn’t.
> >>> Is this expected?
> >>> Thanks,
> >>> Pierre
