[petsc-dev] Regression in manualpages generation?
Pierre Jolivet
pierre at joliv.et
Tue Apr 6 08:21:29 CDT 2021
Thanks for the recent MR.
This sadly only partially addresses the issue.
https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html <https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html> correctly has MatGetRow_MPIDense while https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html> hasn’t.
Pierre
> On 3 Apr 2021, at 1:24 PM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> I think this was likely a non-portable regex that was being used to match the function signatures,
> causing it to miss anything with an internal "s" in the function name. Here's a quick fix for the release branch:
> https://gitlab.com/petsc/petsc/-/merge_requests/3813 <https://gitlab.com/petsc/petsc/-/merge_requests/3813>
> (This sort of thing will become easier to work with, soon, as we'll have an automated doc build which can be examined for each MR.)
> P.S. nice email address!
>> Am 03.04.2021 um 11:19 schrieb Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>>:
>> That isn't expected - thanks for pointing this out! I can reproduce locally so will take a look.
>>> Am 03.04.2021 um 11:10 schrieb Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>:
>>> Hello,
>>> https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html <https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html> lists available implementations while https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html <https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html> doesn’t.
>>> Is this expected?
>>> Thanks,
>>> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/12bd14a9/attachment.html>
