[petsc-dev] Regression in manualpages generation?
    Pierre Jolivet
    pierre at joliv.et
    Tue Apr  6 10:53:08 CDT 2021
> On 6 Apr 2021, at 5:03 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> https://www.mcs.anl.gov/petsc/petsc-current/ is from petsc-3.15.0 -
> and is normally gets updated with the next patch release - i.e
> petsc-3.15.1. [ok - I'll update now with current release snapshot]
Ah, of course, I don’t know why I checked there instead of the dev version, my bad.
Well, thank you for updating the 3.15.0 pages as well I guess.
Pierre
> Also dev pages should get updated daily [there is a bug here
> that I should fix]
> With the latest snapshots - both the pages appear to list MatGetRow_MPIDense
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html
> https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatGetRow.html
> Satish
> On Tue, 6 Apr 2021, Pierre Jolivet wrote:
>> Thanks for the recent MR.
>> This sadly only partially addresses the issue.
>> https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html <https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html> correctly has MatGetRow_MPIDense while https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html> hasn’t.
>> Thanks,
>> Pierre
>>> On 3 Apr 2021, at 1:24 PM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
>>> I think this was likely a non-portable regex that was being used to match the function signatures,
>>> causing it to miss anything with an internal "s" in the function name. Here's a quick fix for the release branch:
>>> https://gitlab.com/petsc/petsc/-/merge_requests/3813 <https://gitlab.com/petsc/petsc/-/merge_requests/3813>
>>> (This sort of thing will become easier to work with, soon, as we'll have an automated doc build which can be examined for each MR.)
>>> P.S. nice email address!
>>>> Am 03.04.2021 um 11:19 schrieb Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>>:
>>>> That isn't expected - thanks for pointing this out! I can reproduce locally so will take a look.
>>>>> Am 03.04.2021 um 11:10 schrieb Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>:
>>>>> Hello,
>>>>> https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html <https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html> lists available implementations while https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html <https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html> doesn’t.
>>>>> Is this expected?
>>>>> Thanks,
>>>>> Pierre
