[petsc-dev] Petsc: Error code 1
    Chen Gang
    569615491 at qq.com
    Mon Apr  5 23:33:06 CDT 2021
Dear sir,
The result of make check is OK. And I do set the timeout to a larger value, which keeps me from getting timeout error. The thing is I have two machines. And I get the error code 1 in different tests on different machines.I don’t know what is error code1. What case this? How can I fix the failure tests.
------------------ Original ------------------
Date: Tue,Apr 6,2021 0:18 PM
To: Chen Gang <569615491 at qq.com>
Cc: petsc-dev <petsc-dev at mcs.anl.gov>, cglwdm <cglwdm at scu.edu.cn>
Subject: Re: [petsc-dev] Petsc: Error code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/cc33c1fa/attachment.html>
