[petsc-dev] Petsc: Error code 1
    Satish Balay
    balay at mcs.anl.gov
    Mon Apr  5 23:36:26 CDT 2021
Try:
make alltests TIMEOUT=600
And send us the complete log (alltests.log)
Satish
On Tue, 6 Apr 2021, Chen Gang wrote:
> Dear sir,
> The result of make check is OK. And I do set the timeout to a larger value, which keeps me from getting timeout error. The thing is I have two machines. And I get the error code 1 in different tests on different machines.I don’t know what is error code1. What case this? How can I fix the failure tests.
> ------------------ Original ------------------
> From: Satish Balay <balay at mcs.anl.gov>
> Date: Tue,Apr 6,2021 0:18 PM
> To: Chen Gang <569615491 at qq.com>
> Cc: petsc-dev <petsc-dev at mcs.anl.gov>, cglwdm <cglwdm at scu.edu.cn>
> Subject: Re: [petsc-dev] Petsc: Error code 1
