[petsc-dev] Petsc: Error code 1
Mon Apr 5 23:18:27 CDT 2021
To check the install - we suggest:
make check
'make test' runs the full test suite.
Note the test suite is parallel - so if using '-j' the multiple
parallel jobs can overload the machine and slow things down.  So best
to use a much smaller -j value, and with a larger timeout.
make -j4 test TIMEOUT=600
Satish
On Tue, 6 Apr 2021, Chen Gang wrote:
> Dear Professor,
> I was running the petsc test using
> # make all test -j
> AND I got the error code 1 message of six examples.
> What is error code 1 and how can location the error.
> I went the exactly file and make, it seems the examples can be running well. I don't understand what is error code 1.
> The below is the summary.
> Looking forward to hearing you!
> #   Summary
> # FAILED diff-tao_complementarity_tutorials-blackscholes_2 diff-tao_bound_tutorials-plate2f_2 diff-tao_complementarity_tutorials-blackscholes_6 diff-tao_bound_tutorials-plate2f_1 diff-vec_is_is_tutorials-ex2f_1 diff-tao_complementarity_tutorials-blackscholes_7
> # success 7544/9528 tests (79.2%)
> # failed 6/9528 tests (0.1%)
> # todo 225/9528 tests (2.4%)
> # skip 1753/9528 tests (18.4%)
> # Wall clock time for tests: 1552 sec
> # Approximate CPU time (not incl. build time): 106566.87999999993 sec
> # To rerun failed tests:
> #     /opt/rh/devtoolset-9/root/usr/bin/gmake -f gmakefile test test-fail=1
> # Timing summary (actual test time / total CPU time):
> #   mat_tests-ex44_mpiio_15: 220.10 sec / 221.33 sec
> #   mat_tests-ex44_stdio_15: 220.07 sec / 221.15 sec
> #   dm_impls_stag_tests-ex1_basic_2: 209.29 sec / 211.16 sec
> #   dm_tutorials-ex15_3: 177.42 sec / 178.46 sec
> #   dm_impls_stag_tutorials-ex6_4: 177.10 sec / 178.31 sec
> Best,
> Gang Chen
> Sichuan Univertsity,
> School of Mathematics,
> Chengdu, China
