[petsc-dev] speeding up testing by not always downloading external packages?
Barry Smith bsmith at petsc.dev
Sun Oct 11 20:39:25 CDT 2020
> Might have a bigger impact if we can improve petsc-pkg-hash
> infrastructure to avoid rebuilds in more cases. [i.e make it more
> tolerant to configure changes - but its not clear to me - which
> changes wont require rebuilds]
I think we currently save the hash of config/ directory and other information like the compilers and environment with the installed package,
We should only hash the part of config/ for all the "active" config/packages and ignore the inactive ones. For example if the build does not use hypre don't include hypre.py in the hash. Doing this is not terribly difficult.
  Barry
> On Oct 11, 2020, at 1:38 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Well I don't think the download time is significant [for all the
> builds at ANL] - as compared to the build times.
> For ex: most of the time - petsc-pkg-hash gets reused [and this saves
> on both downloads and builds] - such builds take about 2h. But when
> packages have to be rebuilt - it can take 2:45 to 3h [so download part
> must be pretty small]
> But yeah - its wasted bandwidth - and not tolerant to network
> disruptions.
> And the other issue: might help with CI on low-bandwidth locations
> [say run a CI instance at my house on a spare laptop]
> But yes - this requires infrastructure. The way I look at it is - we
> need a "local mirror" or "cache" infrastructure.
> i.e keep the cache part separate from the build part [and not intertwine them]
> Spack does stuff in this direction [and also has remote cache as one
> of the 100 remote sites from where the packages can downloaded can be
> down - but its not tolerant to certain changes - so I have to
> periodically clean it - to have confidence in my build].
> Note: If there is a git repo locally cached (and mirrored) - we don't
> have to deal with shallow clones.
> Satish
> On Sun, 11 Oct 2020, Barry Smith wrote:
>>  Satish,
>>   Do you think the time to download all the external packages for each job is significant?
>>   Would using super shallow clones on the external packages help much in time? Maybe we should to them anyways to stop wasting bandwidth?
>>   Currently we do full clones? but we don't need the huge histories.
>>   A much more elaborate way to save more time
>>     On each test machine have repositories of all the external packages
>>     For each job,
>>         do pull in all these repositories from remote that job depends on (usually this will get nothing so take no time)
>>        For each package either
>>            - build in a unique build directory of the repository directory directly (for CMAKE and packages that support out of base directory builds)
>>            - make a local shallow clone of the local copy of the repository to externalpackages for the rest and do those builds there
>>       The average cost of this will just some shallow local clones instead of copying over from remote machines.
>>       The PETSc test directories can still be completely   cleaned out for each job so Satish need not worry about testing with dirty directories.
>>       This requires a bit of infrastructure, if it saves a minute it is not worth it, but if it cuts the pipeline time from 180 minutes to 150 maybe?
>>       Probably not worth it. Could also be done just for a couple of the most external package intense jobs.
>>  Barry
