[petsc-dev] speeding up testing by not always downloading external packages?
Sun Oct 11 14:11:21 CDT 2020
Also when multiple pipelines are running about the same time - there
are dependencies [with job scheduling] that results them in all taking
longer time [improving this requires redundancy in every type of
resource, linux, osx, bsd, and scheduling features to prioritize
stage1 over stage2 over stage3 jobs etc.. scheduling so that stage-3
jobs don't block stage-2 jobs - but then - the preempted pipelines get
delayed]
Satish
On Sun, 11 Oct 2020, Satish Balay via petsc-dev wrote:
> A few other related things to do:
> - add more stage1 jobs (and resources) that can catch failures early -
>   but don't increase stage-1 time.
> - improving stage-2 jobs time - this requires gitlab scheduler
>   features [higher priority jobs over others]
>   and reducing the work currently done by some of the longer (stage-2)
>   jobs [this cost is dependent on if pkgs need rebuilding or not
>   etc..]
> Satish
> > Well I don't think the download time is significant [for all the
> > builds at ANL] - as compared to the build times.
> > For ex: most of the time - petsc-pkg-hash gets reused [and this saves
> > on both downloads and builds] - such builds take about 2h. But when
> > packages have to be rebuilt - it can take 2:45 to 3h [so download part
> > must be pretty small]
> > But yeah - its wasted bandwidth - and not tolerant to network
> > disruptions.
> > And the other issue: might help with CI on low-bandwidth locations
> > [say run a CI instance at my house on a spare laptop]
> > But yes - this requires infrastructure. The way I look at it is - we
> > need a "local mirror" or "cache" infrastructure.
> > i.e keep the cache part separate from the build part [and not intertwine them]
> > Spack does stuff in this direction [and also has remote cache as one
> > of the 100 remote sites from where the packages can downloaded can be
> > down - but its not tolerant to certain changes - so I have to
> > periodically clean it - to have confidence in my build].
> > Note: If there is a git repo locally cached (and mirrored) - we don't
> > have to deal with shallow clones.
> > Might have a bigger impact if we can improve petsc-pkg-hash
> > infrastructure to avoid rebuilds in more cases. [i.e make it more
> > tolerant to configure changes - but its not clear to me - which
> > changes wont require rebuilds]
> > Satish
> > On Sun, 11 Oct 2020, Barry Smith wrote:
> > >   Satish,
> > >    Do you think the time to download all the external packages for each job is significant?
> > >    Would using super shallow clones on the external packages help much in time? Maybe we should to them anyways to stop wasting bandwidth?
> > >    Currently we do full clones? but we don't need the huge histories.
> > >    A much more elaborate way to save more time
> > >      On each test machine have repositories of all the external packages
> > >      For each job,
> > >          do pull in all these repositories from remote that job depends on (usually this will get nothing so take no time)
> > >         For each package either
> > >             - build in a unique build directory of the repository directory directly (for CMAKE and packages that support out of base directory builds)
> > >             - make a local shallow clone of the local copy of the repository to externalpackages for the rest and do those builds there
> > >        The average cost of this will just some shallow local clones instead of copying over from remote machines.
> > >        The PETSc test directories can still be completely   cleaned out for each job so Satish need not worry about testing with dirty directories.
> > >        This requires a bit of infrastructure, if it saves a minute it is not worth it, but if it cuts the pipeline time from 180 minutes to 150 maybe?
> > >        Probably not worth it. Could also be done just for a couple of the most external package intense jobs.
> > >   Barry
