[petsc-dev] Get a list of package download URL
    Blaise A Bourdin
    bourdin at lsu.edu
    Wed Nov 18 17:39:10 CST 2020
I am working with a company whose cluster is an a private network without connectivity to the outside world. Our process to install petsc is to manually extract the packages URL from config/BuildSystem/packages/ and download the appropriate files.
Another approach is to run configure and let it fail when it cannot download a package, note the download URL, and manually download it from a separate machine.
Is there a quicker way to get the URL of all packages that will be downloaded without running through the whole configure process?
Assuming that I know the list of package that I will want, is there a programmatic way to figure out what os the download URL for say Metis or sowing?
Blaise
A.K. & Shirley Barton Professor of  Mathematics
Adjunct Professor of Mechanical Engineering
Adjunct of the Center for Computation & Technology
Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin
