[petsc-dev] Can I call PetscSectionAddDof(s, p, ndof) at a shred 'p' by more than one processors?
Matthew Knepley
knepley at gmail.com
Thu Nov 19 15:50:26 CST 2020
On Thu, Nov 19, 2020 at 4:35 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Matt,
> At a local section point (including ghost point), how to find all the
> owners? For example, proc[0] and proc[2] share p. How proc[0] find that
> proc[2] is an owner? Any routine would provide this info?
All ownership data is handled by the PetscSF, the Section just stores local
information about data. You can ask
the SF is a point is a leaf, meaning that it is not owned. You can also ask
for an owned point, how many other
processes have it as a leaf:
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PetscSF/PetscSFComputeDegreeBegin.html
Matt
> Hong
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, November 18, 2020 1:56 PM
> *To:* Lawrence Mitchell <wence at gmx.li>
> *Cc:* Zhang, Hong <hzhang at mcs.anl.gov>; petsc-dev <petsc-dev at mcs.anl.gov>
> *Subject:* Re: [petsc-dev] Can I call PetscSectionAddDof(s, p, ndof) at a
> On Wed, Nov 18, 2020 at 2:19 PM Lawrence Mitchell <wence at gmx.li> wrote:
> > On 18 Nov 2020, at 15:26, Zhang, Hong via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > Matt or Jed,
> > Can I call PetscSectionAddDof(s,p,ndof) at a shred 'p' by more than one
> processors? For example,
> > if (rank == 0) {
> > PetscSectionAddDof(s,p,1) ;
> > } else if (rank == 1) {
> > PetscSectionAddDof(s,p,2) ;
> > Then, at shared 'p', section 's' has dof=3?
> Sections are "local" objects that are tied together by an SF that
> describes point ownership.
> So I think that the only thing you need is that if two processes set a dof
> on what is globally the same point, they should agree on how many dofs live
> there.
> I wonder if PetscSectionAddDof (etc...) should be marked as logically
> collective.
> Right now, what you want is handled by creating a global Section from a
> local Section:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PetscSection/PetscSectionCreateGlobalSection.html
> The global Section contains global offsets for all local points, and the
> ghost points have negative offsets.
> There is no facility for combining dofs. The idea is that you know the
> number of dofs on each local point. If you change that
> interpretation, you could easily use SF to add them up and broadcast the
> sum.
> Thanks,
> Matt
> Lawrence
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201119/1a122952/attachment.html>
