[petsc-dev] Something is wrong with testing
    Scott Kruger
    kruger at txcorp.com
    Mon Nov 16 11:50:42 CST 2020
It's doing the right thing:
 From src/dm/impls/plex/tests/ex35.c:
  build:
     requires: !define(PETSC_USE_64BIT_INDICES) double !complex
!define(PETSC_HAVE_VALGRIND)
So because you have it defined PETSC_HAVE_VALGRIND,  it's instructed to
skip the build and thus
you have:
# SKIP Null requirement not met:
The language is confusing because it's like a double negative, but it's
reporting the right thing.
Scott
On 11/16/20 10:37 AM, Matthew Knepley wrote:
> On Mon, Nov 16, 2020 at 11:36 AM Satish Balay <balay at mcs.anl.gov
> <mailto:balay at mcs.anl.gov>> wrote:
>     Works fine for me - so don't know whats different in your env -
>     that is triggerig this.
> I had PETSC_HAVE_VALGRIND defined. When I remove it, everything works
> fine. Why is that killing the test system?
>   Thanks,
>      Matt
>     Satish
>     [balay at pj01 petsc]$ make test
>     globsearch="dm_impls_plex_tests-ex35_tet" TIMEOUT=5000
>     Using MAKEFLAGS: -- TIMEOUT=5000
>     globsearch=dm_impls_plex_tests-ex35_tet
>               CC arch-linux-c-debug/tests/dm/impls/plex/tests/ex35.o
>          CLINKER arch-linux-c-debug/tests/dm/impls/plex/tests/ex35
>             TEST
>     arch-linux-c-debug/tests/counts/dm_impls_plex_tests-ex35_tet.counts
>      ok dm_impls_plex_tests-ex35_tet
>      ok diff-dm_impls_plex_tests-ex35_tet
>     #   Summary
>     # success 2/2 tests (100.0%)
>     # failed 0/2 tests (0.0%)
>     # todo 0/2 tests (0.0%)
>     # skip 0/2 tests (0.0%)
>     # Wall clock time for tests: 0 sec
>     # Approximate CPU time (not incl. build time): 0.05 sec
>     # Timing summary (actual test time / total CPU time):
>     #   dm_impls_plex_tests-ex35_tet: 0.05 sec / 0.05 sec
>     [balay at pj01 petsc]$ grep PETSC_HAVE_VALGRIND
>     arch-linux-c-debug/include/petscconf.h
>     On Mon, 16 Nov 2020, Matthew Knepley wrote:
>     > WIth the latest master I get
>     > knepley/feature-tetgen-labels $:/PETSc3/petsc/petsc-pylith$
>     > PETSC_ARCH=arch-master-debug make -f ./gmakefile test
>     > globsearch="dm_impls_plex_tests-ex35_tet" TIMEOUT=5000 EXTRA_O
>     > PTIONS=""
>     > Using MAKEFLAGS: EXTRA_OPTIONS= TIMEOUT=5000
>     >         TEST
>     > arch-master-debug/tests/counts/dm_impls_plex_tests-ex35_tet.counts
>     >  ok dm_impls_plex_tests-ex35_tet # SKIP Null requirement not met:
>     > define(PETSC_HAVE_VALGRIND), Null requirement not met:
>     > I cannot trace it through yet. I reconfigured and rebuilt, and I
>     still get
>     > this. Does anyone know what is happening?
>     > Is it connected to the latest valgrind thing?
>     >   Thanks,
>     >      Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201116/a02228b4/attachment-0001.html>
