[petsc-dev] Something is wrong with testing
    Matthew Knepley
    knepley at gmail.com
    Mon Nov 16 12:29:08 CST 2020
On Mon, Nov 16, 2020 at 12:50 PM Scott Kruger <kruger at txcorp.com> wrote:
> It's doing the right thing:
> From src/dm/impls/plex/tests/ex35.c:
>  build:
>     requires: !define(PETSC_USE_64BIT_INDICES) double !complex
> !define(PETSC_HAVE_VALGRIND)
> So because you have it defined PETSC_HAVE_VALGRIND,  it's instructed to
> skip the build and thus
> you have:
> # SKIP Null requirement not met:
> The language is confusing because it's like a double negative, but it's
> reporting the right thing.
Thanks Scott. Now I understand.
   Matt
> Scott
> On 11/16/20 10:37 AM, Matthew Knepley wrote:
> On Mon, Nov 16, 2020 at 11:36 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> Works fine for me - so don't know whats different in your env - that is
>> triggerig this.
> I had PETSC_HAVE_VALGRIND defined. When I remove it, everything works
> fine. Why is that killing the test system?
>   Thanks,
>      Matt
>> Satish
>> [balay at pj01 petsc]$ make test globsearch="dm_impls_plex_tests-ex35_tet"
>> TIMEOUT=5000
>> Using MAKEFLAGS: -- TIMEOUT=5000 globsearch=dm_impls_plex_tests-ex35_tet
>>           CC arch-linux-c-debug/tests/dm/impls/plex/tests/ex35.o
>>      CLINKER arch-linux-c-debug/tests/dm/impls/plex/tests/ex35
>>         TEST
>> arch-linux-c-debug/tests/counts/dm_impls_plex_tests-ex35_tet.counts
>>  ok dm_impls_plex_tests-ex35_tet
>>  ok diff-dm_impls_plex_tests-ex35_tet
>> #   Summary
>> # success 2/2 tests (100.0%)
>> # failed 0/2 tests (0.0%)
>> # todo 0/2 tests (0.0%)
>> # skip 0/2 tests (0.0%)
>> # Wall clock time for tests: 0 sec
>> # Approximate CPU time (not incl. build time): 0.05 sec
>> # Timing summary (actual test time / total CPU time):
>> #   dm_impls_plex_tests-ex35_tet: 0.05 sec / 0.05 sec
>> [balay at pj01 petsc]$ grep PETSC_HAVE_VALGRIND
>> arch-linux-c-debug/include/petscconf.h
>> On Mon, 16 Nov 2020, Matthew Knepley wrote:
>> > WIth the latest master I get
>> > knepley/feature-tetgen-labels $:/PETSc3/petsc/petsc-pylith$
>> > PETSC_ARCH=arch-master-debug make -f ./gmakefile test
>> > globsearch="dm_impls_plex_tests-ex35_tet" TIMEOUT=5000 EXTRA_O
>> > PTIONS=""
>> > Using MAKEFLAGS: EXTRA_OPTIONS= TIMEOUT=5000
>> >         TEST
>> > arch-master-debug/tests/counts/dm_impls_plex_tests-ex35_tet.counts
>> >  ok dm_impls_plex_tests-ex35_tet # SKIP Null requirement not met:
>> > define(PETSC_HAVE_VALGRIND), Null requirement not met:
>> > I cannot trace it through yet. I reconfigured and rebuilt, and I still
>> get
>> > this. Does anyone know what is happening?
>> > Is it connected to the latest valgrind thing?
>> >   Thanks,
>> >      Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201116/10dd0adf/attachment.html>
