[petsc-dev] Something is wrong with testing
Mon Nov 16 11:37:13 CST 2020
On Mon, Nov 16, 2020 at 11:36 AM Satish Balay <balay at mcs.anl.gov> wrote:
> Works fine for me - so don't know whats different in your env - that is
> triggerig this.
I had PETSC_HAVE_VALGRIND defined. When I remove it, everything works fine.
Why is that killing the test system?
     Matt
> Satish
> [balay at pj01 petsc]$ make test globsearch="dm_impls_plex_tests-ex35_tet"
> TIMEOUT=5000
> Using MAKEFLAGS: -- TIMEOUT=5000 globsearch=dm_impls_plex_tests-ex35_tet
>           CC arch-linux-c-debug/tests/dm/impls/plex/tests/ex35.o
>      CLINKER arch-linux-c-debug/tests/dm/impls/plex/tests/ex35
>         TEST
> arch-linux-c-debug/tests/counts/dm_impls_plex_tests-ex35_tet.counts
>  ok dm_impls_plex_tests-ex35_tet
>  ok diff-dm_impls_plex_tests-ex35_tet
> #   Summary
> # success 2/2 tests (100.0%)
> # failed 0/2 tests (0.0%)
> # todo 0/2 tests (0.0%)
> # skip 0/2 tests (0.0%)
> # Wall clock time for tests: 0 sec
> # Approximate CPU time (not incl. build time): 0.05 sec
> # Timing summary (actual test time / total CPU time):
> #   dm_impls_plex_tests-ex35_tet: 0.05 sec / 0.05 sec
> [balay at pj01 petsc]$ grep PETSC_HAVE_VALGRIND
> arch-linux-c-debug/include/petscconf.h
> On Mon, 16 Nov 2020, Matthew Knepley wrote:
> > WIth the latest master I get
> > knepley/feature-tetgen-labels $:/PETSc3/petsc/petsc-pylith$
> > PETSC_ARCH=arch-master-debug make -f ./gmakefile test
> > globsearch="dm_impls_plex_tests-ex35_tet" TIMEOUT=5000 EXTRA_O
> > PTIONS=""
> > Using MAKEFLAGS: EXTRA_OPTIONS= TIMEOUT=5000
> >         TEST
> > arch-master-debug/tests/counts/dm_impls_plex_tests-ex35_tet.counts
> >  ok dm_impls_plex_tests-ex35_tet # SKIP Null requirement not met:
> > define(PETSC_HAVE_VALGRIND), Null requirement not met:
> > I cannot trace it through yet. I reconfigured and rebuilt, and I still
> get
> > this. Does anyone know what is happening?
> > Is it connected to the latest valgrind thing?
> >   Thanks,
> >      Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201116/29c1c623/attachment.html>
