[petsc-dev] MATOP_MAT_MULT
Stefano Zampini
stefano.zampini at gmail.com
Sat May 9 05:45:29 CDT 2020
Jose
I have just pushed a test
https://gitlab.com/petsc/petsc/-/blob/d64c2bc63c8d5d1a8c689f1abc762ae2722bba26/src/mat/tests/ex69.c
See if it fits your framework, and feel free to modify the test to add more
checks
Il giorno ven 8 mag 2020 alle ore 18:48 Jose E. Roman <jroman at dsic.upv.es>
ha scritto:
> Attached. Run with -test 1 or -test 2
> > El 8 may 2020, a las 17:14, Stefano Zampini <stefano.zampini at gmail.com>
> escribió:
> > Jose
> > Just send me a MWE and I’ll fix the case for you
> > Thanks
> > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200509/d2b68b8b/attachment.html>
