[petsc-dev] MATOP_MAT_MULT
    Jose E. Roman
    jroman at dsic.upv.es
    Fri May  8 10:48:25 CDT 2020
Attached. Run with -test 1 or -test 2
> El 8 may 2020, a las 17:14, Stefano Zampini <stefano.zampini at gmail.com> escribió:
> Jose
> Just send me a MWE and I’ll fix the case for you
> Thanks
> Stefano
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200508/29059f20/attachment.obj>
