[petsc-dev] MATOP_MAT_MULT
Stefano Zampini stefano.zampini at gmail.com
Sat May 9 06:36:29 CDT 2020
Hong
you may want to take a look at this big commit here
https://gitlab.com/petsc/petsc/-/merge_requests/2712/diffs?commit_id=94a81e695f30a0ff4a14c0eb596e09393f9b329f
Now that you coded MatProduct, I think it is the case of not playing with
the destroy/view routines anymore in the various MatMat operations (you
know, I have raised this issue already in the past). I think I got it fixed
properly. What I did in short, I have added extra slots to the MatProduct
struct to keep track of how to destroy/view the extra information you need
for the products.
Also, I have deprecated MatFreeIntermediateStructures, since we now have
MatProductClear
I have spent quite a bit of time on it, and I personally think it is the
proper way to go. I think I took care of all the cases already covered.
Tests are clean for me
I would like to hear your opinion.
Thanks
Stefano
Il giorno sab 9 mag 2020 alle ore 13:45 Stefano Zampini <
stefano.zampini at gmail.com> ha scritto:
> Jose
> I have just pushed a test
> https://gitlab.com/petsc/petsc/-/blob/d64c2bc63c8d5d1a8c689f1abc762ae2722bba26/src/mat/tests/ex69.c
> See if it fits your framework, and feel free to modify the test to add
> more checks
> Il giorno ven 8 mag 2020 alle ore 18:48 Jose E. Roman <jroman at dsic.upv.es>
> ha scritto:
>> Attached. Run with -test 1 or -test 2
>> > El 8 may 2020, a las 17:14, Stefano Zampini <stefano.zampini at gmail.com>
>> escribió:
>> > Jose
>> > Just send me a MWE and I’ll fix the case for you
>> > Thanks
>> > Stefano
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200509/d0adf3fd/attachment.html>
