[petsc-dev] petsc release plan for march/2020
    Matthew Knepley
    knepley at gmail.com
    Wed Mar 25 20:08:14 CDT 2020
On Wed, Mar 25, 2020 at 9:05 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Wed, Mar 25, 2020 at 8:23 PM Satish Balay via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> >> > > - feature freeze: March 27 say 5PM EST
> >> A reminder, feature freeze is in 2 days. I see the following MRs with
> >> milestone: v3.13-release
> >>     !2598    Add Sphinx docs and port Developers Manual
> >>     !2614    Knepley/feature dm remove hybrid
> >>     !2626    More support for not needing to set PETSC_DIR yet build
> with
> >> PETSc, also...
> >>     !2634    WIP: Balay/release 3.13 revert to dev
> >>     !2554    Knepley/feature fe lagrange gll
> > 2554 is not merging. I will change the target.
> If Toby's branch also isn't merging, is there a stop-gap we can have?  Or
> is Toby's branch merging and the milestone is missing?
This branch will not work because it requires fixes for DMForest which it
will not get in time. Toby said he was very close on his branch.
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200325/e628db3f/attachment.html>
